Delete an Event
Delete an event after you no longer require the alarm information.
  1. In the navigation pane, expand Configuration > Serviceability > RMON.
  2. Select Alarms.
  3. Select the Events tab.
  4. Select the event to delete.
  5. Select Delete.
